1983 Deck Boat Transom/deck/stringer replacement Help
Decker83
Re: 1983 Deck Boat Transom/deck/stringer replacement Help
Thanks Wood and Jigngrub.
I am going to order 5 of the 1" x 3" brass drain tubes from them. Total is $13.75 with free shipping.
Not to bad of a price.
I did see the UV inhibited epoxy on their site. That should make alot of epoxy fan's really happy.
Decker83
Hello Gentlemen,
I did place a order with Raka Inc. The drain tubes I ordered were delivered in about 5 days counting the weekend. I was very pleased with them. They gave me a confirmation email for my order and one for ship date.
We had great weather last week from Monday to Thursday and then on Friday the rain came in and it stayed untill Sunday morning.
Didn't do much on the boat but did presure test the gas tank I have for under the deck. It seamed to hold about 5 lbs for 24 hours.
I was good with that.
Can't complain about the rain to much, we really needed it and we didn't have any real bad storms just a good rain, I had about 3" here.
Hope the rest of you good people had a more productive weekend.
GT1000000
Glad you had some rain and not nasty storms...
The boat is looking really good, I had missed the last set of pics...it is coming together nice...
5psi for 24 hours, sounds good to me, too...
I'm gonna check out Raka Inc...
Excellent idea on the PB Pastry Bag...
Have a great week Decker...
sphelps
Hey Decker, gunna try and make time to read back from the start of your project! Gunna tag along if you got room for a rookie crew member! Nice glassing and fab work you got going there!:cool:
See ya S.P.
Decker83
Thanks GT1M
Welcome aboard S.P. any and all welcome. Thanks for the compliments guys.
Decker83
Well, if the rain lets up in the next few days I will finnish fabricating the fuel tank box. I have the parts cut out and need to put it together and glass it.
One question about the raw fiberglass in the fuel tank box. Does it need to be coated with gelcoat or some other material or just left as raw fiberglass.
jbcurt00
BilgeKote is an option
Woodonglass
I'd recommend either BilgeKote(Gasoline Resistant) or GelCoat. Would not leave it bare. R U lovin the Rain as much as me!!!! My lake is gunna fill up I Think/Hope!!!!
Decker83
Thanks JB and Wood. I think I will use the gelcoat.
Yeah I do like the rain. Need it badly here. Just don't like the storms that come with it.
Some of the lakes have come up quit a bit in the last month. Still need more.
rickryder
Nice job Decker! I did the same trick with the PB and ziploc bag. Make quick work of laying a bead of PB. A big metal spoon dipped in acetone makes a nice fillet too ;)
Jon Sob
Master Chief Petty Officer
Great job Decker your work looks clean and neat and good idea with the ziploc and the PB. Thanks for sharing the idea.
SouthTexan
Looking great! Before you know it you will be in the water, keep up the good work!
Woodonglass
Did you get some Rain?? We sure did!!!!!:D My favorite lake is 9' low so I'm hopin she'll come up a bit. Looking forward to seeing some progress pics of your project.
Decker83
I do like the spoon ideal too.
Decker83
First I would like to say thanks to Trooper for his input and comments. I didn't mean to miss you but I have a one track mind. (that's when my mind is working) :facepalm:
Thanks Jon Sob and South Texan for the comments.. It's kinda funny about the zip lock bags, a long time back I use to lay up the culture stone (man made) on fire places. We would use a vinyl bag with a metal tip to fill the cracks between the stone with mortar. It worked good for this so I thought the zip lock bags would work for the PB.
Wood are lakes have filled up and some or over filled in East Texas. Some of the lakes or still down in West Texas. Hope the rain brings your lake back up to full level.
So I have some pics for all of you that are interested. I tell you that my old body says I must have worked two weeks straight but the work I did says I only worked a couple of days.:eek:
Here is where I finnished putting in the storage boxes. I mixed up about 1/2 gallon of PB and spread it on the transom and sides of boxes and set them in place. They feel very solid and have a nice solid sound when I tap them with a hammer.
I also have built a fuel cell compartment for the under deck fuel tank. Used almost a sheet of 3/4 x 4 x 8 plywood.
Put it together and did the fillets and started the glassing. I was only able to get the ends and bottom done today. It took some work to go over the 2x2 braces on the bottom. I have the 1.5 csm and then a layer of the 1708.
I didn't have any air bubbles but it took alot of work.
Decker83
Here is a pic of the bottom of the fuel cell box.
This is a pic of the compartment between the storage boxes. This will be filled with pour in foam.
I have some gel coat from us composite coming on Monday so I will be able to coat the inside of the fuel cell box and the bilge area this week if it dosn't rain me out.
Thanks for looking. Hope everone had a good weekend.
Woodonglass
Decker
Your Grandkids, When they are your age, will be enjoying the TANK, that you are building. VERY NICE WORK!!!!!
rickryder
Thats lookin great!
Trooper82
Yup nice progress decker. Like your idea to make a box for the gas tank.
Looking real good!
Decker83
Hello to everyone here.
Have done alittle more work this last weekend. Here or some pic's for the pic lovers. :)
Here is the fuel cell box I drilled 3 holes at each end to allow any water to drain out, if any does get in.
Here I have put 2 coats of gel coat on the inside. I also used PB with alot of chop strand in it and coated the holes using pipe cleaners. I also used the same method to coat the holes with gel coat.
The first gel coat I applied was without wax and then as it started to get real tacky I put the 2nd coat with wax. It did very well.
I also did the same thing on the transom and bilge area.
I also went down the keel with gel coat. The way the foam in the boat was done it didn't have foam there.
