1983 I think Force Motor with no Pee Hole
AZTRAILBOSS
I bought this Motor for a boat that I picked up cheep. It does start and run but there is no pee hole. no tube off the top of the head. is this normal. Where does it come out at. While running I see that it is spitting out of the two holes with the exhaust on the back. I am also looking for any manual on this thing. what is a good compression on it.
The controls on the boat do not mach up so I will have too engineer new mounts and the wiring will have to be made to work.
what is the kill wire on the motor
I got a Lowe aluminum boat to put this on but it leaks alot does the diy kit work for a rino lining?
Will SS screws work to replace rivits?
Any advice
Thanks K
AZTRAILBOSS
Re: 1983 I think Force Motor with no Pee Hole
Thanks for the link. I was able to finds some info on the motor. Is it possible to install a pee hole. seems like you just don't know how well that pump is doing it's job.
It's like the rino-lining people say it is a good idea but I can't find a thread that says yes I did it and it has been good for the last 5 yrs.
If you know what I mean.
anyone have any clue
foodfisher
Rhino liner is ok "IF" it's put on a solid surface prepped properly. No wobbly rivets or corrosion. Put a bandaid on cancer and it looks ok till the bandaid falls off. Try the rhino liner ? on the restoration forum.
fucawi
Banned
your force at 83 comes from just after Force took over Chrysler ...Chryslers did not have a standard pee hole ....the two vents are just to keep exhaust pressure down for starting and low speed running ...you will have to fit a pee hole yourself ... you will probably find a plug in the top of the head/block remove and fit a pipe ..it will be a taper thread ..take your plug to a bolt ship or air line fittings place ...small pipe 1/8 outlet is sufficient at the casing to give a strong jet you can see easlily
AZTRAILBOSS
That sounds like a great idea. I will take that plug out and tap it so that I can see how well the pump is doing. i just how i didn't get a lemon when i bought this craigs list motor. had to take the word of the seller that it ran. I will have to do a compression check and decarb the piston.
thanks for your input
