Re: 1983 Thompson 29ft express Flybridge Help!!!
Hi-
Always helps to post specifics about the engine(s) and drive system (make and model). There're plenty of drivetrains of that vintage that I wouldn't touch because they're either obsolete or prone to issues (like Mercruiser 3.7 engines) Does it have A/C? On-board generator?
You're looking at a 30 year old boat. Brand is practically irrelevant at that age, and old boats tend to have issues. If you know how to confirm integrity of the hull, stringers and transom, then you know what to do. If you don't, hire a surveyor. Same for the mechanicals. Go over the boat with a fine-toothed comb. The subsystems (plumbing and electrical) can cost a lot of money to fix, and they're usually buried pretty well, so labor becomes a big factor. Is the head system legal for where you'll use it (with holding tank)?
In short, you need to check that boat inside and out so you know exactly what you're buying.
