1984 3.7 swap to a 1979 898
hadaveha
the donor boat mercruiser 898 (chevy 305) swap with my 1984 3.7 does this make any sence, the donor boat can be bought super reasonable. I was going to go with 4.3 but I found this donor boat and just wanted to explore the idea.
thankyou everyone for your ideas
achris
More fish than mountain goat
Re: 1984 3.7 swap to a 1979 898
As long as you get the drive and transom plates, then swap EVERYTHING over. The 898 will not bolt up to the 1984 inner transom plate.
Anything can be made to fit with enough time and money, swap everyything as Achris says. You might also have to modify the engine mounting in the front.
stonyloam
You might want to consider the size of the boat you are swapping into, the V8 will be about 400 pounds heavier than the 3.7.
hadaveha
yes I knew it would be quite the job, I think what Im really asking is more about the 898 is it a good step up from the 3.7 and how does is stack up against the 4.3
achris
Believe it or not, the 4.3 is a better engine...
Chris.....
Chris.....
Ayuh,.... The 4.3l is 'bout 100 lbs lighter, 'n 'bout the same horsepower as the 5.0l,...
thumpar
Yep the 4.3l is much better than a 305. They make about the same power. The only way I would switch it out to a V8 is for a 5.7.
stonyloam
the current outdrive would be correct for the 4.3, not so much for the 305.
achris
Yep, 2 bbl 305 used a 1.65:1, 4 bbl used 1.50:1.... 470 and earlier 4.3 used 1.84:1
