logger8614
- Mar 18, 2009
- 7
I have waited along time to generate this post due to aol. ( filter problems) Thanks to the moderators I am now able , after months of just being able to read pertinent posts, ask the knowledgeable board members a question: My Johnson , model number J90TLCTE, has a drop or a misfire at rpms over 4000. This problem first presented itself as a major drop in rpms and speed followed by an abrupt increase in speed and rpms followed by a decrease ad nauseum. Shop number one could not duplicate in test and did rough justice by replacing power packs. 400$ and no change. Shop #2 replaced the stator I believe( blue ring underflywheel attached to throttle advance) and no change. Shop # 3 replaced one secondary ignition coil and while the significant drop and increase in rpms has stopped there is still a misfire or drop above roughly 4000 rpms. Here is what I believe to be an interesting piece of the puzzle. Every trip, starting to WOT it is fine. Whole shot is strong, rpms are at 5300-5400 and top speed is 45-48mph. After about 25-30 minutes at WOT or after a couple of stops to fly fish for stripers, it starts with the intermittent hiccup. Real quick. So fast the tach does not even register the drop but I can hear it and feel it.
Being that I have limited funds, have been dissatisfied by three shops and am about to get laid off from my teaching job in California, I would like to try to tackle the problem myself. I am armed with a shop manual and a voltage meter and that's about it. After reading the many posts on iboats about these engines I am convinced its electrical in nature. I pulled the fuel tank and replaced fuel lines. the bulb is always firm. None of these shops have mentioned bad compression or weak spark as a problem.
I have two theories based on what I have read and what I think I can tackle myself without making matters worse.
The secondary ignition coils(old three) look possibly original. The plastic housing is starting to break down and the drop changed in characteristic after the last shop replaced the coil on the lower left cylinder on the side of the fuel pump. So I could replace the other three although I assume he would have checked them when he found one to be faulty. The other idea is to rebuild fuel pump as it is long over due and because the pulse of cylinder #4 initates the pump it may be fouling the cylinder or plug. The spark plug on the lower left cylinder (fuel pump side) has a little bit of fuel mixture getting by or maybe because it is the cylinder that has the problem was bucking the plug loose and allowing seepage.
If I am forgetting any important information please remind me and I welcome any and all opinions including the fact that it is a 25 year old motor and the fact that it still runs moderately good should be enough and to stop chasing perfection.
Eagerly awaiting the boards input,
Joe
Joe
