SEGAangler
- Jun 23, 2013
- 69
Re: 1984 Evinrude 150 stator
Yes, your understanding on the top half of post #19 is correct. I have had 1 wire that came loose from the plug (power pack to stator) that I have corrected and subsequently checked all the wires. That was very early in this process-before the stator was replaced. However since I have moved all the components numerous times I will check them again. I did get fire on all 6 for a short period just awhile ago. I had it with everything hooked up (stop circuit included). I put the plugs back in and tried to crank the motor...as soon as it tried to fire off the 1st time I lost spark on the starboard bank yet again. Since that, all I have done is disconnect the stop circuit again and retest timer base ohms (readings good).
