I replaced the main cylinder on the bottom because it was leaking, bad, got it fixed no leaks from there. There are no visible leaks anywhere.
is there any test to see why its leaking down.
It will stay up at random times and random positions then if i touch it at all it will start dropping until it catches again. I filled it up and bled it multiple times check connections and repeated, its not loosing fluid but wont stay put.
Main lift cylinder might be shot but wanted to see if there was some sort of test before i bought a rebuild kit or a new cylinder.
Motor serial number 1258X4A
