goblerblaster
- Dec 26, 2011
- 180
I have an 1984 Johnson 15 hp -model #J15RCRM-. When I bought it a few months ago, it was hard to start the first time, but then was fairly easy to start- 5 or 6 pulls- after that over the course of several weeks. I ran it in a barrel with a heavy dose of Seafoam. It would idle as long as I wanted it to- like over an hour at a time. Finally took it to the lake and it started as usual but would not plane the boat when I opened the throttle, bogging down and dying. Brought it home and put a carb kit on it. Carb was really dirty and the float gasket had crumbled up inside the float bowl. I put it back together , pumped the bulb, and it started on 2nd pull. Took it to the lake and it started on first pull and it ran WOT perfect, and it idled perfect. I disconnected the gas line and let it idle until it seemed to run out of .gas.
I brought it home and a week later took it back to the lake. Motor sputtered on first rope pull then started and idled perfect on the second pull. I was letting it idle and heard the idle speed up like it was running out of gas. In a few seconds it died and would not even hit much less restart. It had maybe idled for 20 seconds total. I had noticed that when I went to pump the gas bulb- after hooking up the fuel connector to the motor - I noticed that the bulb was already hard and it didn't feel like any gas was being pumped into the motor. This was before I started it, but I didn't think much about that until it died and would not re-start. I assumed that the float must be stuck and not letting any gas in. I figured there must have been some gas left in the carb from when I ran it a week ago and that was what had just run out. Brought it home...
I removed the fuel line from the carb and pumped the bulb. Gas was coming out of the fuel line. I pulled the starter rope and gas would squirt out of the fuel line, so I assume the fuel pump is working. When I would pump the bulb hard- I mean really squeeze it hard- I got to seeing gas coming out of the front of the carb, so I figured the needle valve was not blocking the gas from getting to the carb when the float bowl was full of gas. I took the carb apart and blew air through it, checked for clogged jets, etc. and could find no problem. So, I reinstalled the carb, pumped the bulb- this time it felt normal when pumping like gas was going into the carb- and it still will not even hit. This time I could not pump the bulb hard enough to make gas come out of the front of the carb. I checked the plugs and they are getting good spark. I thought maybe it was flooded , so I waited 2 hours and tried again. Still not hitting. Pulled the spark plugs and squirted gas into the plug holes. Still won't hit. I waited 2 more hours and tried again- same result.
Any ideas???
Any ideas???
