Hello all!
I have a 1984 Mercury 9.8 that had enough issues with the lower unit that I figured it would be cheaper and easier to swap out the whole unit. I found a used one locally at a Mercury dealer that was a bit newer. The original bad one has an O-ring below the splines on the drive shaft and the driveshaft splines are about 1.25" long. The new is identical except it has no O-ring and the splines on the driveshaft are about 3/4" long. I tried installing the new unit and found it wouldn't go all the way into the powerhead - there was about 1/8" gap between the lower unit and the midsection. When I removed the new lower unit I found that the splines are likely not long enough because there was a burr at bottom of the spline grooves.
So, can I safely dremel the spline grooves so they are 1/8" longer? I was assured by the seller that the lack of the O-ring wouldn't be an issue, but is that true? Can I just dremel out a space for an O-Ring there too? I'd really like to not remove the driveshaft - that seems like a big undertaking...
Thank you!
Thank you!
