Woodonglass
- Dec 29, 2009
- 25,930
Got the paper back veneer on and started coating it. Looking ok so far, but there are some bubbles in it that I think are caused by my adhesive.
Love the ribbon striped sapele!!!
Bubbles in the Veneer or in the Clear Coat?? If it's in the veneer use a T-Pin to poke a hole in the bubble and then a J-Roller to roll out the air and press the veneer back down. If its bubbles in the Clear Coat, Wet sand em out and then on the next coat use a Hair dryer to help heat the surface and raise the air bubbles to the surface. What clear coat are you using?
