erosenwinkel
- Apr 22, 2011
- 130
I have a 1985 Force 125 hp outboard (1258x5a) that I recently had rebuilt due to overheating . I believe the impeller was shot and wasn't pumping. Also when I was pulling the engine apart to take it to the machine shop I pulled off a cover then pulled out a spring and fished out a worn/completely stuck plastic plug (bypass valve) It was solidly seized up inside the bottom of the engine and it took quite a bit of work to get it out. It has since been replaced with a new spring and plastic plug. Does anyone have an idea what the working operation of this plug/valve is? Does it need to be replaced or inspected regularly? Did its initial imobility have a contributing role in the overheat that happened? I know the impeller was not in very good shape upon its removal. After putting the engine back together, everything works great. Water pumping like a firehose, engine nice and cool. Any further explanation greatly appreciated. Thanks!
