1985 Evinrude 4hp no spark.
kalebsheridan
Hey all,
I have a 1985 4 HP with no spark. Ran a few years ago when I last started and now I'm trying to fix it up again. Don't know how these point and condenser style ignitions work so here I am. Tried doing the old grounding the spark plug trick with no spark. Plugs are good, grounded them using another outboard to test them. Popped the flywheel off and everything looks pretty new. Any ideas?
saltchuckmatt
Hey all,
Points and condensers all work the same, why are you baffled by these?
Anywho, the real men will be by shortly to instruct you how to learn!
Crosbyman
common magneto for ages start by just cleaning up the points with 200 grit paper then clean wih carb cleaner or acetone and retry. your coils are the newer kind and should show no cracks whatsoever.
rotate & set the rub block on the points cam at the highest point and check or adj. points to .020 gap should be good enough. Add 2 drops of oil on the small felt pad.
if no spark measure the ohms value from the boots to the engine block it should se 4-8 Koms approx. make certain coil wires to the condensers don't rub on the crankshaft !!
change gear oil... you carb may or may not need an overall depending if the engine was stored
properly (short term I leave mine full of fuel.... long term I run them dry
water pump impeller should be changed depending how many years ago it was stored... it doesn't hurt anyway ... up to you
check utubes ... lots of info
this free book for older engines contains all the info you need to since carbs and magnetos are mostly the same...the ignition section on old jw cd ad qd..... models of the 50s and 60s is the same. great reading anyway. print or store locally
https://www.socalaomci.com/library/johnson_service_manual_10th_edition.pdf
great kickers btw....
Disconnect the ground wire and test the coil with an ohmmeter. The primary wires should have nearly a dead short. A few tenths of an ohm resistance is good. Test the spark plug wire to the ground wire. It should have some resistance and not be open, nor a dead short. Clean the points and make sure they mate when they close. Set the points on the high lobe of the cam at .020 in, and make sure they close when on the flat part of the lobe.
Condensers go bad at random times. Test the rest of the ign system and if it is good, replace the condensers.
kalebsheridan
Well for context this motor is almost 2x older than me so it's like trying to decipher Egyptian hyroglifics. But yes hopefully some useful responses will show up.
kalebsheridan
Awesome I'll get on that and report back
The magneto on that motor was first installed in 1950.----Installed for the next 40 years on motors from 1.5 to 40 HP.---An elegantly simple / easy to maintain unit.----That is an opinion shared by many people.
Crosbyman
Just go buy new coils they are cheap.
actually that generation of coils does not crack like the ones from the 1950s.... (see picture)..... if there are no obvious defects ( cracks) one should look elswhere . investing in condensers may be more timely.
some of the newer "non OEM" 20$ coils will sometimes leave me suspicious because the secondaries can read up to 8.5 9 Kohms...
Easy stuff first. Replacing coils is not difficult but it takes pratice.
