So I'm down to the point with my project boat that it's time to try and start it up. No telling how long this thing hasn't ran. I replaced the water impeller and changed the lower unit oil. Also had to replace the fuel hose as the old primer bulb and hose were shot.
So this weekend I get some time to try and start her up. Attempt 1: get it to crank, choke solenoid works, no start. Attempt 2: same thing. So I get my dad who's on vacation to help m crank it while check for spark at the plugs, by grounding them out on the block. No spark on either one. Hmmm. I double check my wiring and everything looks right. So I take the flywheel off and looks like the points aren't opening correctly or the gap isn't set right, plus they are really dirty. I clean them up with some 400 grit sandpaper and set the gap to .020 (did a search on here and found that as the correct gap in a thread). I put it all back together and attempt 3: Tries to start a couple times, I can see fuel sometimes spitting out the front of the carb and sometimes the motor wants to kick back. I get my dad to help me check the spark again, this time I have spark on plug #2, no spark on #1 though. Swap the coils around, no change, swap plug wires and plugs, no change.
So with all that out of the way, I think I have some bad points or condenser. Sound correct to you guys? This is my first boat, and first engine with points, so I'm in some murky waters here. I was going to replace the parts but everywhere I look the tune-up kit FK1075 is discontinued or sold out. Where can I get parts to get this old dog running at?
Thanks,
Aaron
Thanks,
Aaron
