1985 j115tlco cant get fly wheel off?
mhyder63ford
trying to remove fly wheel to change rectifier/ regulator. i have the nut lose on top, and using a fly wheel puller wont budge?
You tighten the center bolt as much as you dare.----Then give the center bolt a hefty bump with a ball peen hammer .
gm280
Are you using this type flywheel puller?
If so make certain the bolts you are using are grade 8. Because anything less will break. Then like racerone stated, tighten as tight as you can and rap the center bolt with a good size ball peen hammer. If the doesn't break it loose, tighten some more and continue with the ball peen. I ended up using a pneumatic impact wrench myself on the center bolt and it popped off... JMHO!
?????----Really.------The water cooled regulator / rectifier is mounted on top of the block.---------Removing the flywheel certainly makes the job easier !
mhyder63ford
yes thats the puller i'm using. and i do have grade 8 bolts, and using impact gun to tight center bolt. also put some pb blaster on it and still no luck. and yes you have to take the fly wheel off to change the reg/rect on this motor. no wat to get back bolts out if you dont.
mhyder63ford
got her pretty tight going to let it set over night and see what happens. is it possible to heat it with a torch? or not a good idea
The proper puller works every time.----Heat should not be used here !!
Auxlarry
I just pulled mine a couple weeks ago and had the same issue....took about 8 hours of torque, beat, pb blaster and waiting before it finally popped loose while I was away at dinner!! Be patient, it will come off!!
These flimsy pullers flex too much.---Just do not work like the factory puller !!!!
interalian
A good take-away from this comment: don't remove the nut - just loosen it a few turns. Keeps the flywheel from popping off, and maybe falling somewhere it can get or cause damage.
mhyder63ford
i agree racerone but hard to swallow a 110.00 for a puller your going to use one time. but it did come lose went out this morning and it had popped lose. now just waiting on the mail man. thank you guys for the help.
Most shops would pull that for you in minutes.-That would be time and money well spent.-Using heat and other brute force risks damage to big $$$ parts .
gm280
I have to say good for you getting it removed. But remember, you have to make absolutely sure that both the flywheel AND the tapered crankshaft section are totally clean and dry without any oil or lube on them when you put it back on...
mhyder63ford
thank you gm280 will do putting back together this week end and i believe the torque on the nut is 100-105 ftlb ?
