888MFG
- Aug 21, 2018
- 25
Engine would not start. When it started it ran great. Slow starter. Replaced 4 coils, starter, and solenoid. Problem still slow turn starter. Tested wires to battery. Voltage drop of 7 volts. Replaced all wires with 2 gauge as was original. Now the boat starts great. It will not accelerate. Before would go to 4500, 5000 rpm. Now full throttle only 3000. Sometimes bogs down when trying to reach the 3000 and quits. Fuel is fresh, mix is correct. I hope it is not the fuel pump but since it was running well before I replaced the parts. I am going to try cleaning the carb jets for the high speed as I do not need to remove the carbs to do this. Could this be the fuel/water separator? Ideas?
