jtexas
 - Oct 13, 2003
 - 8,646
Re: 1985 Johnson 60Hp motor truning over very slow
don't dry 'em with a towel - even a little piece of lint can get in there & mess with ya.
yeah, the dealer ought to have the gaskets in stock, also replace the needle valves & valve seats. It's better to just get the kit - the oem kit cost about $20 more than the sierra kits you get on iboats but includes a new float - but you can usually re-use the float unless its saturated or falling apart.
Johnsons run best on Champions - better not to use NGK if you can help it - my experience has been that the NGK center electrode wears down way faster - others on iboats have blamed NGKs for engine failures - not knocking NGK they are great plugs in the right application but for some reason OMC motors don't like 'em.
get the fuel line from the johnson dealer if its like mine, it's an oddball size
I'm guessing you had to set the idle so high because it was dropping a cylinder - recommend put the spring back on before firing it up again.
