Re: 1985 Johnson 70hp VRO no key start?
You can buy a key from the dealer. Check for a letter code around the housing around the key switch. Or just take the boat to the dealer and have them use their "try out ring" to locate the proper key. There aren't very many to try. You might also check one of your local locksmiths. They can often cut one for you even though you don't have a master. Some are good at this, some are not.
