1985 Mercury 115 problems
Dmunch
Got a boat that was sitting for 8 years, ran it for the first time and worked well until the end of the day. It lost power at full throttle and would only run at about 2400 rpm. Runs fine out of the water and I put in new plugs. Once in the water under a load, it has now power and sputters. Got a new tank and fuel filter. Didn't help it.......Any suggestions?
Chris1956
Re: 1985 Mecury 115 problems
Sure, Take a compression test and a spark test. If those are good, clean and rebuild the carbs. Replace the waterpump impeller and the gear oil. Now retest
Dmunch
Re: 1985 Mercury 115 problems
How do I test the compression? Do I need a tool?
Dmunch
I found 3 wires coming from the switchbox that were rotted (plastic split, wires green and barely connected). Could this be the problem or just another problem????
canoemang
Fix those wires and also follow the directions Chris gave..
jimmbo
Take out all the sparkplugs to do the compression test
Dmunch
compression is 91-93 on all carbs and all have spark. I'm going to rebuild the carbs and fuel pump this weekend and see if that works.
