1986 30hp midsection is loose
ba_50
E30ELCDM
There is about 1/4" of space when pulling back on the lower unit and seems to have too much play. is this normal?
Also, is the bolt with slot used for steering tension?
thank you.
Re: 1986 30hp midsection is loose
That screw is for the steering tension.----------Remove lower mounting bracket for inspection of mounts.
Bosunsmate
whats with all the brown oil down the front?
