1986 40 hp Evinrude (E40ELCD) 'Pee Stream'
rlray42
I've had this motor (used) for couple of years now & it runs great! Yesterday, I noticed the pee stream was just a dribble. (Kinda like my pee stream, lol) and since we have had some debris in the water, I decided to install a new water pump impeller. (I didn't find any sign of debris in the pump) Afterward I tested the motor in a tank and the pee stream is no better...
I did see there is a fair amount of water coming out the exhaust ports plus a lot of water coming out from under the lower cowling near the front of the motor. (Maybe this is normal & I just noticed it?)
Any thoughts or suggestions appreciated.
Richard
ps. Also, I'm willing to provide tips to anyone regarding the water pump replacement on the motor.
Will Bark
Re: 1986 40 hp Evinrude (E40ELCD) 'Pee Stream'
Run a piece of string trimmer line up the pee hole and see if a bug has clogged it up. Good luck
rlray42
Will, THAT DID IT!!! Thank You So Much! So Easy! Well, at least I now have a new water pump impeller.
Thanks again..
Richard
Watermann
Good news, and yes that's normal for water running out from the front of the lower cowl.
rlray42
Thanks 'Waterman' - Being 70 years old (& retired) I chose to spend my $ wisely & use 'affordable' fishing equipment. (wife says I cheap) Plus, I've tinkered with outboards my whole adult life and really do like the relative simplicity of the 70s - 80s motors. (compared to today's models)
I'm embarrassed that I didn't think about the pee tube being clogged.
Disconnecting the shift rod on this one was a 'bear' but accomplished after I finally removed the bottom carb and starter.
I enjoyed looking at your Sea Nymph project! Hoping your health improves quickly so you can get 'er on the water!
Richard
rlray42
Took the boat out yesterday and now it makes a 'clunk' one or two times after shifting into forward & advancing the throttle a bit. (Kinda like it isn't engaging into gear completely) After that all is ok.
I'm wondering if I could have gotten the shift rod rotated 180 degrees off? Would that cause this 'clunk'?
Thx, Richard
