glenn property of pam
- Feb 17, 2012
- 2,906
went fishing today. motor started first go with a little choke then we ran 10 mins in no wake zone. went to power up on plane and motor seemed week and stuttery (2-3 seconds) then came up to full power and the boat got on plane no problem. back throttle to 4200 rpm and trimed then the motor suddenly seemed to gain 400 rpm and alot more power then 10 seconds later loss 400 rpm and power. it seemed to be doing it every 10 - 20 seconds. if i throttled up to 5200 rpm it seemed more stable. after stopping and fishing for a bit we moved on and the engine seemed to do it again and again during the day . i checked for weeds etc and could see no problem the fuel bulb was hard when i checked it while stopped. on the long run in the engine seemed to be running alot better and it ran fine all the way in with no surging. it sounded like i was dropping a cylinder so now im wondering where to start searching for the problem and was hoping someone might have had this problem before.
i was to sunburnt to pull the plugs :facepalm: when i got back so this week im thinking of replacing the plugs (maybe oiled up) draining the carbs (florida so could have water in it) and possible thinking about changing the float needles (maybe one is sticking) any surgestions would be welcome.
