1986 Force 85HP Main Cover Seal
poorboy1990
I am asking a stupid question. I was wondering what I can use to replace the broken seal under the main engine cover? 20190525_124034-2268x3024.jpg
kbh121956
Hi poorboy1990. I have seen them on ebay, They come and go so check often. They call them "Hood cover seal" even sometimes hood packing.
kbh121956
Poorboy1990, I followed you from the StarCraft group. On your 85hp that needs work, ask questions and look for the answers the next morning. Two guys on here are very good pros. Jerryjerry05 and Nordin. Good luck. The part number for it is F321756.
Nordin
Jerrys suggestion might fit but it is for a Force 85Hp and up from 1987 and later.Maybe it can be to short.
As your engine poorboy is a 1985 the lower cowl is different.
You can look at ebay for hood seals for Chrysler 70Hp and up in Hp range as your engine is a rebanded Chrysler.
Seals from mid 60.s and up until 1986 will fit.
jerryjerry05
I posted that one because that's all I could find that might fit.
Measure the one on there and see if it comes close??
The newer model 87+ are 81 inches.
