1986 Mercruiser 260 (GM 350) Cracked Block?
LakeMichiganBoater
Been rehabbing a 1986 Carver Santa Cruz and got the engine running and was testing the cooling system and it leaked a ton. Most were due to loose hoses, but I think I found a crack in the block. Just want to confirm this is not a seam where there should be a gasket that may have failed and it is indeed a cracked block.
IMG_0086.JPGIMG_0087.JPGIMG_0088.JPGIMG_0093.JPGIMG_0095.JPGIMG_0096.JPGIMG_0098.JPGIMG_0099.JPG
Sorry about the pool quality of the photos, had to use my bore scope to see it and capture it. I cant get my head down there to see if it is indeed a crack... but looks like a crack to me.
If it is indeed a crack, what is the best option? Clearly it needs to be pulled, but do I just rebuild it with a new block, shop for used, or use this opportunity to upgrade to something better?
Thanks!!!
Ayuh,.... That's a crack alright,......
Best, easiest fix is another running motor, from another '86 to '95, or a fully dressed '96, 'n up,......
'86 was the 1st year of the 1 pc. rear main seal blocks, 'n '96 was the 1st year for the vortec heads, 'n intake manifolds,....
that is a freeze busted block.
as Bondo stated, get another running motor and swap it.
LakeMichiganBoater
Yeah... I kinda figured...
Is this a good time to upgrade to FI or something bigger that is a drop in? Or just stick with the same engine, new block?
fuel injection will cost you a bunch of extra money for zero gains. however that is up to you.
if it was me, I would take this time to get a complete post 1996 mercruiser long tail and swap in the boat eliminating all OMC
Scott06
Depends on how much you want to spend
you can get a reman or new long block of same generation, get a 96 and up Vortec 5.7 (needs new intake manifold) and gain 40 hp, go for the 383 that kenny mentioned for 400 hp, of get a new MPI bobtail .
From top to bottom for parts alone those options range from $4k to $20k.
Personally I stick with carbed engines because I dont care if it takes a few seconds to start after sitting and you can fix it with a carb kit and a screw driver...
Either way I would plan on replacing the exhaust manifolds, risers, elbows as they are likely cracked too
LakeMichiganBoater
Well I dont want to spend a ton of money, but if I rebuild the engine with a new block I am probably above $1500 as I will probably end up replacing most internal engine parts. So if its under $4000 to upgrade it may be worth it to me. It looks like it may be much more than that.
Any go to places for a new/used 350 block? I am shopping around and they seems to be close to $1000 just for the block, which seems high to me.
Scott06
go to a wrecking yard like LKQ just need to pay attention to the generations of SBC. A marine and truck motor are basically the same thing. That is usually the lowest cost option.
cheapest route would be a running boat with rotten hull and pull the whole assembly.
second cheapest route would be find a running motor in a truck. pull the heads and swap head gaskets to marine. swap out the core plugs to brass. get a new marine circulating pump. buy new exhaust, swap your accessories. inspect the intake. you may need a new intake as well.
In michigan, you should be able to find a rusty truck with a good motor for under $500
Any 1987-1995 GM pickup/van/suburban/Tahoe for your vintage motor
If you want more power, look at 1996-2000 gM trucks and get vortec heads
