1986 Sealion Trailer
Prkzs79
I have a 1986 sea lion trailer. the axle was rusted and fell apart. Does any one know the size of the axle? I can't get a good measurement cause now the wheels buckled outward. How can I fix it?
Re: 1986 Sealion Trailer
Ayuh,...
Take it Appart,...
Size up the broken Parts,....
Buy replacement Parts,....
Reassemble the trailer,...
You're Done....
Prkzs79
I can't size up parts that i don't have but thanks anyway.
Ayuh,...
Where'd they Go,..??..??
On your 1st post you stated the above,...
Prkzs79
The axle was so rusted when i went to move the trailer the axle just crumbled into pieces. The springs are still attached but the wheels a buckled out ward so i can't get a good mesurment. I don't know if they have a typical size or not. Thanks for your help.
Ayuh,...
Measure Between the Springs,...
Measure the distance from the spring perches to the end of the axle,...
That's the Length of the Axle...
Pull a Hub off,... Note the Size of the spinle,...
Take those #s,+ Buy a new axle....
