rammerjammer05
- Feb 17, 2011
- 52
1987 Force 125 1258v7b. I was adjusting the idle mixing screws yesterday and got the bottom carb set at about 1 1/4 turn out from seated. When I moved to the top carb I stared with it at 1 turnout a turned it clockwise (in) but the engine never changed.Got the screw all the way to seated. Basked the idle mixing screw back out to 1 turn out from seated and started to go counter clockwise(out) and again nothing with the motor ever changed. Each time I was doing this I would turn the screw only a little bit at a time to all the engine to catch up. Do I have something wrong with my idle screw on the top carb or should I just set it to 1 1/4 turn out from seated like my bottom carb. Haven't took the screw out yet to see if it's damaged but plan on doing this tomorrow along with a decarb.
