1987 140 inboard mercruiser
Dinoduh30
1987 140 inboard mercruiser 4 wins. When is in fwd running for about 20 min. 3000-3500 rpm it stalls look like it lose power but runs at 1000 rpms. With no problems. I changed fuel filter and try on the water and stalls again same way.not shure what to do thanks
Rick Stephens
Check fuel tank vent, make sure it isn't plugged. Check anti-syphon valve which is located at the fuel line fitting where it connects to the top of your tank.
When you changed the fuel filter, did you dump the contents into a clear container to see if it was clean fuel or contaminated fuel?
Dinoduh30
I will check it out Saturday and look the fuel filter i changed was a little bit shorter than original . I was thinking to add small in line filter and have 2 filters would that be ok.
i have one more issue my throttle cable is bad stretched cant make no adjusted any more it goes in fwd but it want go in rew..not shure what kind i need its my first boat thanks
thumpar
You can take the fuel cap off to see if that helps.
It sounds more like a lower shift cable with what you describe.
Dinoduh30
Didn't check content when i changed fuel filter . Previous owner change fueling hose the bigon2e and wasn't conected wright at fuel tank it was leaking fuel i fix that but i can still smell fuel after wee come from lake and the water that comes in the back small plug got rainbow color in it is that mean that i maybe have a fuel leak somewhere.
i tried took gas cap off but it was same thing it was stalling
when I was home i adjust cable a little bit i was able to shift foward and reverse it was fine but when i went to a lake i could not put in reverse. Cabel is worn out no room to adjust need new one but no clue what kind thanks
Hi Dinoduh30, I recently had a very similar issue with my '94 Sea Ray 170 3.0L Mercruiser. After running at cruising speed 5-10 minutes it would begin to stall out and sometimes die. But would start back up and idle okay. Limp back to the dock, etc. Turned out the original fuel pump had decided to give up the good fight . About $100 later I was back in business. Now will run all day, no problems. I have probably 12 hours on the boat since the repair, water skiing & tubing.
Rick Stephens
Verify that. Pull the line off the carburetor and stick in a bottle. Crank motor and see if fuel comes out. I hate seeing parts thrown at it.
Dinoduh30
Ill definitely do that. You said " pull line of the carburetor " that line will come out of carburetor if you could be more specific sorry new to this thanks.
thumpar
You should have a solid metal line from the fuel pump to the carb. Unscrew the fitting at the carb.
I definitely agree with Rick Stephens about "swapnostics" being a poor substitute for a proper diagnosis, however, after screwing around with figuring out if the siphon valve was blocked, rigging rubber hoses and such I decided to take the drastic step of actually throwing money at the problem. Apparently it cost more than I remembered. Maybe the $100 was the price the Admiral got.....Looks like I used this pump:
Do be careful with the steel fuel pipe, you should have tubing wrenches for this job, if at all possible.
Dinoduh30
I wass adjusting bottom cable i think he goes down somewhere.
Top cable goes to shifter/handle wich one of those 2 i need to adjust the bottom look like its worn out.
Ayuh,..... Welcome Aboard,...... The lower shift cable is much more apt to be the problem, than the forward shift cable,.....
Dinoduh30
I think i adjusted wrong cable i was not supposed to mess with that lower unit cable. So could that be a problem for engine to stall on me . On the picture i adjust bottom one .
i am working on wright now and i removed metal hose fro carburetor to check if fuel pump is pumping fuel it dose pump but not shure how much or fast need to come out when i crank it Screenshot_2018-08-11-19-20-53.pngScreenshot_2018-08-12-12-13-51.png
Dinoduh30
I think i fixed fuel problem change all the fuel related hoses clean filter at carburetor, i had it run at 2500 rpm it was an gaging in reverse but it want go forward so i think its cable issues i try to adjust but no luck i will need someone to look at that.
