Scott06
- Apr 20, 2014
- 7,312
Concern here is if your bearing clearances were set up correctly, which based on what is seen I would bet they are too tight. Hopefully there is documentation of this convo in case You have an issue down the road.They said they always send them with all their engines but nothing on the pressure. The discussion was focused on that I installed a standard flow pump and those numbers.
It sounds like you are looking at all the right things hopefully water test is good
