1987 5.7 omc outdrive
Nick_1987 5.7 OMC
Get a genuine OMC service manual. That way you will know about the special tools that are needed. Most likely you just need to wash out the upper. Since all the “V” style engines use the same lower you should be able to locate a rebuilt or used unit.
Sierra Marine has the seal kit for the upper and every else you will need.
So I can use any lower unit? Even from a 4.3 or 3 liter outdrive?
Nick_1987 5.7 OMC
While your upper may look ok don’t forget that the bits of the failed gears are spread through the whole drive because the lube supply is share with the upper & lower. I would try and see if there is a local shop that could do it, it might be tough because of parts & special tools availability. You could try to put in an insurance claim but it looks like an internal failure not from hitting an underwater object which would be covered. So you have some choices:
Local disassembly of upper gear unit & cleaning and checking bearings & gears and replace the lower with rebuilt unit
Use the SEI conversion kit to convert the Cobra to an aftermarket copy of the Merc Alpha drive.
From what I’ve seen rebuilt Cobras go from 2500-3000; the SEI kit is cheaper but the quality of the SEI drives is variable some good reports as some bad. I guess you could also use their kit with a used genuine Merc drive.
other options cost more as I said in other posts it depends on how much the boat is worth to you. The Volvo conversion is $$$ but good for repairability and resale, converting the whole works to a Merc (pull engine, replace transom mount & drive with Merc) is probably cost wise the same or a little cheaper than Volvo conversion but is a lot of labor cost unless you can do all yourself. If you had to replace the engine or rebuild the transom this would make sense otherwise it’s a lot of extra labor.
Are the bottom ends the same for 5.7 and 4.3 from 86-93 ?
Lou C
There are differences in that the older 4 cyl ones had a smaller lower unit the first few years but at some point they all started using the V6/V8 large gearcase lower unit. Might be from 1990 & up you have to check
Lou C
So the lowers are the same the gear ratio changes are done in the upper unit.
Lou C
youre welcome just make sure to really check things....maybe get an OMC shop manual if you can find one that will help a lot.
