1987 Eliminator Jet Boat Hull Repair
WaterWitch2
I'm repairing an Eliminator boat with a minor crack in the hull. Should I be using epoxy or polyester resin and what type of cloth should I use? I know I should post some pictures and I will shortly.
oops!
Re: 1987 Eliminator Jet Boat Hull Repair
yep...we need to see pics
also we need to know how powerful the boat is.....that will determine the poly/ epoxy thing....and that will determine the type of cloth or matt.
if its a standard jet boat...poly will be fine..
there is more to it....so post pics when you can.
cheers
oops
WaterWitch2
I just cut out the deck to see all the "fun coming up". Pics are coming tomorrow.
WaterWitch2
It's not so minor of a crack. It's about 3 ft long. It has a 454 Chevy and runs around 70 MPH. What do you guys think?
Ayuh,... That's Well beyond most DIYer's abilities to repair...
That needs to be all cut out,+ Restored...
Yes,.. I'd use epoxy...
