jerryjerry05
- May 7, 2008
- 18,183
Jets don't wear out..
They can corrode and the hole enlarge.
Yes, sorry, was planning to do that just forgot to mention. In the meantime I did take apart the recirc plates top and bottom. Some crud in the screens but nothing blocking and the reeds are straight/flat. Will clean and make sure I can blow through all passages then put back together.Do the starting fluid test!!!
I see. I had an 88 and presumed it has the same type of fuel recirc. Anyways, follow Jerry with his recommendation. The plugs fouling on bottom cylinders like yours is a perfect example of a clog or malfunctioning fuel recirc system. You would have to trace it all to make sure. In fact, it would not surprise me this was the cause of the stuttering to start with.Thanks. This '87 appears to be the reed type - the Clymers doesn't mention check valves in the elbows like it does for the other years/hp - do you think there might still be a check valve to check? Definitely not on the plates, but maybe the block?
errorView attachment 369155View attachment 369156
Looks like I've got the newer block (1258V7B) - two hoses for two dog bone-shaped top and bottom recirc plates. The hoses look to feed the intake ports directly as I can only blow into them as I move the piston to certain positions. Will get some brake clean/compressed air in there and make sure I have good flow.
What about the reed stops for the recirc system here? I looked in the Clymers and there is no specification for how much gap there should be to allow the reeds to open. Any ideas? Some of them are different then the others, but they are all set with very little gap.
One other thought as I wait for new gaskets (yeah I know, I could have made some) - about the shudder, I noticed the Clymers said that the 1985's had a top and bottom carb main jet of .094, whereas for '87 it is .101 for top only. The parts diagrams don't mention this so I have this jetted for .101 per my elevation, which is 1200 ft above sea level. I have 1985 carbs (1258V5A) on a 1987 powerhead so which one should I use? I find it interesting that the top carb is the one that I can tune to 3/4 out on the idle circuit and get rid of the shudder, whereas the bottom carb doesn
You're right Jiggz, the manual says that if the recirc system isn't working properly, it could show the kind of symptom I'm seeing. I hope that's all it is, but I'm not seeing anything glaring after taking it all apart, so will see. Hopefully can get it together this week end and test for a Labor Day c
Thank you! My thoughts exactly, just wasn't sure whether to jet for the block or jet for for the carbs.
