1987 Johnson 110
87Starcraft
I’m having trouble find a rebuild kit for a fuel pump. Anyone have any leads on a good parts site?
VRO pump or the regular pump ?-----And what is the motor doing / not doing ?
87Starcraft
Regular pump. Motor is fine just bought it and want to do a tune up
87Starcraft
I want to rephrase that question I’m not loooing for a parts site just need to fine where I can get a or rebuild kit
There are different pumps that fit.------The only thing I would do is a new diaphragm if inspection shows it is bad.-----What do you mean by---" tune up "-----Electronic ignition , timing that does not change and fixed jet carburetors.---Makes a traditional tune up a thing of the past.-----Most important thing is a compression test.----Post your numbers here.
87Starcraft
Spark plugs, rebuild carbs, and rebuild fuel pump. From what I read on 2 strokes of the carbs are not functioning 100% they will run rich and you won’t get the correct amount of oil in the motor
