I have no power to the Red/Blue hot wire....there is actually some, just .19 AMPS.
A bit of history first:
I killed the old battery from leaving an accessory on CRANK-CRANK, CLICK-CLICK. I had it load tested and it was junk, so I replaced it with the battery shown below. After installing it, I didn't test the motor, just the fish finder and lights and thought I was good to go. I go on the river yesterday, and nothing happened when I turn the key. I tried to rope start it, tried racking the gear lever into neutral, still nothing.
I did a bunch of reading here, and tried jumping the neutral safety switch with no luck. I checked the fuse under the bonnet, cleaned the connection in the harness plug, cleaned battery leads. Found no power at the ignition switch. There is also no power on the thin yellow wire at the starter solenoid with the switch on.
