Hi Tommy, thanks so much for helping out with my jet issue, the one jet I sent a picture of was a broken one, I've attached what the remaining 5 jets look like.
Since putting in the stock fixed jets I have eliminated my lean condition sneeze at idle, however my new problem is pulling out of the hole, this occurs upon first use or sitting for about an hour, I can't even get it to plain, once warmed up it's just OK at best, I would say once warmed up it would be the same as before replacing the jets. If I were to throttle up while putting on the trailer it barely has enough to push forward, in fact if I were to apply full throttle it would die. Almost acts like too much fuel and not enough advance.
I don't think changing the jets I would have altered the linkage as I removed the linkage via the cotter pins. All butterflies are closed. I looked at link and sync in my Selnoc book and am confused as how to do a link and sync. Do you think main jets could cause this problem?
Back to the beginning, bought this boat for skiing and bass fishing, no way it could pull me out.
1750 procomp, 150 mariner, 6 inch jack plate, hot foot, 14.25 X 22 Trophy prop with vent holes open. It acts like its over propped WOT 55mph at 5,000 RPM . My first impression is I just need to change my prop, however it seems most people with similar boats are running 23 to 26.
I will post
