1987 Mercury 70 hp low compression?
dantheACman
I took the power head apart to get it ready to ship off and decide to remove the crank and now that I have power head apart I have done all the hard work this is really simple to me a 25 year refrigeration tech I rebuild compressor way more complex than this I just never took to many 2 stroke a parts any way I found local place that will bore and hone my question which should I buy a whole rebuild kit or just Pistons the bearings look and feel great two of the three piston look rough cylinder wall not bad at all I can fell a slight grove with finger but not really not that bad if I had to guess I would say a 100th of inch or .010 I just don't want to be lazy but I can't see any reason to replace bearing what you guys think and also wsm piston or wiseco piston and where is the best place to buy piston and or rebuild kits
Pistons are the first to suffer.-Crank and bearings are very tough on outboards.-----Most times they can be re-used with no problems.---Make sure you find the cause of the failure or you will be doing the job again !
dantheACman
No Title
I just bought the engine my guess from looking up online is the failure is from it was a oil injection motor and someone bypassed or did away with so it's from lack of lubrication it only a guess or just was used a lot I'm going to post some pic see what you guys think
dantheACman
Got motor back from machine shop starting rebuild what should I use for holding needle bearings together can I use any kind of assembly lube or does it need to special manual says Mercury needle bearing assembly lube and no other go opus but I can't find it very easily any suggestions would be greatly appreciated
dantheACman
Rebuilt power head carbs new spark plugs rebuilt fuel pump new water pump I have broke in about 6 hours runs like a champ way more power than before so I decide to do compression test again I had it bored .030 wsm piston complete rebuild kit it was actually something I like doing I'm always working something with my trade and this was fun I used Johnny evinrude needle grease it was just overpriced Vaseline anyway to the point I checked compression again expecting hi numbers no I built a really cool compression tester using digital gauges very accurate I couldn't believe it 83.7 82.9 80.7 I don't understand so my stroke is 5.5:1 just thought I would up date
dantheACman
I'm still in break in process so I have not held at wot for over a minute but wot to get on plane and always changing rpms using 32:1 mix spark plugs look good got the old boat up to 36 mph at 4750 rpm 13.25 x 19 prop I just confused on compression any thoughts
