1987 Power Play XLT-185 - floors, stringers, and upholstery
Reserector_
Chief Petty Officer" & 2021 Splash of the Year Win
Clamp a scrap of plywood across the inside of the keyhole in the hull and check the "depth" from the outer hull surface to the plywood. That way, if you have any gaps that are going to hold off your plywood transom, you will be able to see and measure it.
PB might add another 0.040" like you say, but that won't be significant.
todhunter
Canoeist
I got another layer of 1708 down on the transom tonight. Before laying it down, I cut a spot out in the keyhole and measured the total thickness after the first layer of 1708 - about 1.575". That means one layer of 1708 added roughly 0.050" of thickness, so after tonight's layer, I should be about 1.625". Add 0.040" for the PB and 0.250" for the transom glass thickness, that puts me at around 1.9" thick, right about where I want to be. So, this should be the last layer of glass going onto the face of the transom. This coming weekend I'll clean up all the edges and start figuring out clamping and alignment for installing the transom. I've still got to replace my drain plug too.
Laying out the glass. Again, I broke it up into 3 separate pieces, with the seams a mirror image of where the first layer's seams were.
My daughter had the idea for us to trace our hand prints into the glass before I laid it.
Fully wet out.
kcassells
You animal! Looks great! I usually let the glass overhang of the edges @ 1". Not to make the edge curve transition but knowing the glass gets short/long on wet out. Ten simply use a multi tool with metal blade to trim back.
todhunter
Canoeist
Tonight I cut another spot out in the keyhole to measure in the same spot - right at 1.620 - 1.625", which is right where I want to be. Tomorrow I'll get the edges cleaned up.
kcassells
Did you get to wrap some glass around the edges of the transom. I would recommend that. Even something like the lightweight stuff used for car patches from an auto or HD store. Wraps around edges real easy. Will seal off the edges that on bottom will be subject to water in the bilge.
todhunter
Canoeist
Yessir, if you look back at post #127 in this thread, I laid CSM around the border of the entire transom, in the keyhole, and in both exhaust holes before I glassed the front face. The entire transom is now fully encapsulated.
todhunter
Canoeist
A little detour from the transom - where can I find replacement flaps for my 4" exhaust pipes? Both thru-hull pipes look like this, where half of the flap is gone. The pin that the rubber flap rides on is welded in - I am capable of cutting the tacks and re-welding myself if I can find replacement flaps. Or is there a more serviceable option besides welding the pin back in?
EDIT: Would something like this work? :
todhunter
Canoeist
I've made a lot of progress this weekend. I got the glass trimmed out of the keyhole, exhaust holes, and all around the edges of the transom, and all the edges are sanded smooth. I am going to use my exhaust pipes to help align the transom during installation, so I taped them up to protect them from getting resin on them. I test fit the transom in the boat, laid out my clamps, and built some additional 2x4 clamps. I also got the old garboard drain off and test fit the new bronze one.
Transom laid in the boat with taped up exhaust pipes helping align everything.
A view to both sides of the transom showing the exhaust pipes.
Transom all clamped up.
Close-up of the extra wood on the 2x4 clamps to apply even pressure out on the edges.
Old garboard drain removed.
New garboard drain fitting test fit.
tpenfield
Your fiberglass work is outstanding. (y) :cool:
You may find the stringer glassing a bit more challenging, but keep the under side of the cloth wetted as you have been doing and let the resin soak outward through the cloth. (y)
todhunter
Canoeist
Thanks for the words, and for the tips, guys.
I spent 2 hours tonight with a plastic chisel and a can of WD-40 cleaning the silicone off the back of the transom. What a pain. I've probably got another hour worth of scraping tomorrow and then it should be good enough.
Reserector_
An "eraser wheel" in your drill will take that off and leave it looking like it was never there. Eraser wheels are mostly used for removing old decals and pinstripes without hurting paint or gelcoat. 3M makes them.
todhunter
Canoeist
I tried the eraser wheel and it didn't work on the silicone so I just kept at it with the plastic chisel and WD-40 and got the majority of it off. I got all the small screw/bolt holes on the back of the transom masked and masked around the exhaust holes and keyhole. I attached plastic below them to catch any drips runs. I'm off work for 2 weeks starting tomorrow and plan to get the transom PB'd and clamped in place on Monday.
kcassells
Yea sorry... I missed the speed you worked. So those kind of penetrations you made should be lubed out with some kinda grease, wd 40, vaseline etc. for future guys doing this. You can spread any of the above on the bolts and areas where the squeeze out occurs. Usually it will wipe right off.
todhunter
Canoeist
We got home from the weekend trip earlier than expected, so I had my wife help me PB the transom to the boat this afternoon. She did great by helping make PB while I spread it and also helping with the clamping and wiping up the squeeze-out. I should be able to start laying fillets and tabbing tomorrow. Thanks @Reserector_ for the last minute tips today.
Everything laid out prior to the transom installation. I rolled out a coat of resin on the transom plywood (actually already coated in 1 layer of CSM on the back face), spread the PB onto the fiberglass with a 1/4" v-notch trowel, and clamped with a bunch of bar clamps, deep c-clamps, and 2x4 clamps.
My wife mixing up the PB. She did a great job.
Transom clamped and waiting to cure.
