Bt Doctur
- Aug 29, 2004
- 19,465
Re: 1987 Searay 268 with twin merc 470"s
It`s basically water in =water out. verify the impeller work is correct. the pump assembled correctly or it can suck in hot exaust instead of water. from the impeller it goes thru the water pocker cover. this item is prone to destruction by a severe overheat and leaks water coming up from the impeller.from here it goes thru the connecting hose between drive and transom. A kinked hose or internal collapse will cause lack of water flow. from here thru the connector fitting inside the boat. overtightening the clamp crushes the plastic fitting, no /reduced water flow. from there to the heat exchanger, thru the exchanger and out the riser/elbow.clogger riser/elbow prevents water from leaving the cooling system
You cant, dosent work that way, you need to remove the drive first.
