1987 Wellcraft Gran sport rotation
rmo5095
Hello all, I have a 1987 Well Craft Gran sport 454 mercs. V-Drives. Due to the fact that the starboard motor is missing the heads I am trying to determine if these motors are counter rotating or are they the same rotation and changed in the transmissions? Thanks.
Ayuh,...... Welcome Aboard,...... The odds are 9999.9 to 1 that they're standard lefthanded motors,.....
achris
More fish than mountain goat
Look at the distributor caps.
Chris.......
rmo5095
Thanks for the response, so if this is true is the rotation changed in the transmission, I would imagine these are counter rotating correct?
achris
The usual practice is for the starboard propeller to be spinning CW (standard rotation) and the port prop to be spinning CCW (counter rotation). Since most engines are CCW (as viewed from the flywheel), a 'standard' transmission reverses the rotation. So a 'reverse rotation' transmission will have the same direction going in as coming out. Yes, it sounds counter-intuitive.
Chris......
