Re: 1987 Yahmaha 150 HP outboard injection oil transfer problem
check the engine tank switch, white to black should show continuity when the float is up. once the brown wire to black closes the pump wont turn off until the switch gives the oil control module a ground signal from the white wire.
the float is a 3 position switch, all the way up white is grounded,midway down brown is grounded, all the way down and red is grounded and you get RPM reduction and an audible.
