1988 50hp evinrude NO spark
sambrigman
It has been running ok, put it in the water no spark at all. I disconnected kill wires. no good.should the coils have fire when the ignition is on? Any ideas or suggestion greatly appreciated. How to trouble shoot?? Thanks guys
oldboat1
Always check spark with an open air tester. Make sure the throttle lever is in the neutral detent, if getting no starter activity. xLIS50850_1200Wx1200H.jpg.pagespeed.ic.DpYWD8n9Ep.jpg
Sorry,---12 volts from the battery is not used to make spark on this motor.-----Spark is generated by the magneto under the flywheel.----And only if the starter motor spins the flywheel at about 250 RPM.-----So inspect your starter and have battery load tested.
oldboat1
If you have cranking issues (too slow), your flywheel will accept a rope for starting. Using a spark tester, remove both plugs to give it the best chance.
