BlackoutBill21
- Dec 10, 2016
- 181
Ok I have this 9.9 that I found out had a 15 hp carb. I found out cause it never had full power never got above 4000 rpms. After taking the carb out and rebuilding it 100X I started to lose it.
So so I have 3 high speed jet plugs and don’t know which one to use... they have a 50 , 54, and 55 stamped on the side.
i believe it originally came with the 54 which according to my research was for the extended longbshaft sel model sail boat one ... I’m thinking that’s what this carb came off of. Is that why it never ran right?
Its the newer carb with palstic bowl and plastic top
after i put this carb back together and have the same issue, what should I do next?
Compression is 120 each, my spark tester is cheap so I’m not sure how strong it is.
can you check the spark strength by using the plugs?
If its not the carb what else could it be? Thanks in advance
