on my dt85 I have had an issue with varying max revs and stalling when re starting after fishing or it runs and will not let me power up beyond 1000rpm or it will bog and die,so I have replaced the coils ,fuel pump, all fuel connections tested the relative voltages and resistances I can and they all seem good.i went to check the timing today and I get @ 3deg atdc at idle and when I blip it it goes towards btdc but if I gradually increase the revs it will not retard.
So I am wondering if this is my problem.What advances the timing when the revs are increased,I know there is a switch on the middle carb and it seems to be within the specs..
your thought please. also is there a specified gap for the counter to ring gear and the pulsar coils to what ever as I can't see anY specified.
