Re: 1988 evi 15hp wont stop
Hummmm... Have you checked the kill switch for continuity yet? The problem could be as simple as a defective kill switch. Might be a pain in the butt but since the kill switch is located in the tiller arm, find the wires going to it un-hook or simply cut, then using a ohm meter, check for continuity while depressing the kill switch. This is a simple check and should be preformed while the suckers off or you might get a nasty shock. In my experince, its always the simplest things that go out first,... there's just so damn many of them. If this doesnt work, you COULD adjust the Throttle adjustment at the timing advance and see if that would work. I like my engines (tiller controled) to stop when I back completely off the throttle.
