ahickman
- Jul 5, 2012
- 79
Just got back from putting my new (to me) 88 Capri with Force 125 on the river. Had a difficult time starting/idling at the ramp, but got it running and moved up the river about a half mile at 2/3 throttle. Checked to ensure the new water pump was pushing water out the nostrils and was pleased. 20 seconds later, the overheat buzzer went off so I shut it down immediately and removed the cover. Engine/head was not so hot that I could not hold my hand on it. While I had the cover off, my buddy twiddled with the throttle linkage in an effort to bump the idle up a bit since it was having a hard time idling and moving into gear. He also twiddle with the timing screw just under the flywheel. We decided to give the engine a whirl in order to get us back to the dock. From there on out, it ran like crap and could never get it from neutral to forward gear. Just died out and ran like crap.
As I said, I just bought the boat and only changed out the water pump and did compression tests. ~130 psi on all four cylinders. Ran and idle OK in a barrel. Drained all the fuel I could since I didn't know how long it sat. Fresh mixture of 50:1 fuel/oil. Never opened up the carbs or the fuel pump. Did open up and test the thermostat. Worked well in a boiling pot of water. Crusty, but worked.
I really need some guidance on the following:
1. How do I go about setting the timing? Considerable experience on setting timing on Toyota 22RE engines, but none on this boat engine.
2. What is involved in rebuilding/cleaning the carbs? I am good with fuel injection, but know little about carbs.
3. Fuel pump??? When I pump up the buld, it gets good and hard. Fuel spits out of the carbs, so I assume the FP is good to go? Should I just go forward and get the new gasket kit?
Please help!!! I got a great 10 minutes running this boat and am so bummed to have it die on me on the first run...
Thanks,
Aaron
Thanks,
Aaron
