ahickman
- Jul 5, 2012
- 79
Lots of questions regarding an 1988 (model 1251x8c) Force outboard on an 88 Bayliner Capri I just brought home. Yes, I have googled and searched this form for answers first.
1. Trim/Tilt issue: In addition to the trim/tilt switch being flaky, I noticed that the engine trim/tilt does not work. When I released the strap that was securing the engine in the up position, I watched it slowly lower (10 seconds to hit bottom) and assume the seals on the valves are shot. I hit the trim button to see if it would raise and heard the pump run, but no movement. Opened the filler plug on the valve body and could see a bit of clear fluid (not red). Not sure that it is full, however.
Question: How do I best drain the fluid from the pump and what is the proper refill method? Should I use non-detergent 30W motor oil, or move to ATF for this model?
2. Water cooling intake: Am I correct in that the water intake for cooling are the two mesh/vents on the very bottom of the lower unit. They are located on either side of the prop shaft. Just use muffs to properly supply water when testing engine, or can I use a big barrel to sit the prop in. Where is/are the water exit points? Want to make sure I don't have clogged passages or a failed water pump.
3. What fuel mixture is best for this engine? I would like to set up a remote tank until I can get the fuel cell drained and cleaned out. No telling how long the fuel in it has sat.
4. Lower unit gear oil. Not at all sure where to check/fill the existing fluid. Also don't know what fluid I should use to replace after draining.
Any suggestions or pointers would be much appreciated. I am new to this boat and just getting back into the water after 20 years of living inland.
Aaron
Aaron
