1988 Force 125HP tilt leaking down
damax
I just got this boat and the tilt motor works but is leaking down. There are no outside signs of leakage but the motor goes down in about one or two minutes. Can anyone suggest where to start ?? Thanks
jerryjerry05
The trim/ tilt leaks in 3 places.
The pump is usually the culprit.
The trim section(part with the little plunger) can leak but I haven't seen one go bad.
The tilt ram can be the last place.
In the manual there are procedures for testing the system.
You'll need to buy a couple of fittings but it's a pretty easy test.
damax
Thank you SKIDAD. That link gave me all the info I need. Thanks to all
damax
Question no. 2: I should have asked this originally but forgot. Is there supposed to be a warmup position on the throttle control?? I can't find one.
damax
Update: I followed all suggestions and wound up rebuilding both rams, the shock and valve body on the pump. GREAT SUCCESS !!!
Thanks everyone this is the most informative forum ever.
