Jake Blood
- May 26, 2009
- 16
I havea 1988 Johnson 120... it is a VRO, but the VRO is diabled. This boat was running great, but then one trip out it started running sluggish.. it would get up on plane, then nearly stop, then go, then go at low speed ( while still full throttle ), then high speed.. like if you pinched the fuel line, then released, pinched it, then released.. weird. Then after riding for awhile it would run great... Well this last time out, it did the same thing, now all it does is putt along.. at full throttle. I also noticed t one time the gas can.. one of those red outboard gas cans, started getting the air sucke out of it.. it was compressing.. I opened the vent and it went back to normal and did not happen again...
I did check the plugs, and they looked fine, though I may need to have them gapped again?
I took out the high speed jets and cleaned.. those were fine.. are there others I should clean?
The fuel filter was slightly dirty, but even when I bypassed it, it didn't run any better...
Any thougts? I was hoping to go out tomorrow.. I hate to disappoint the boys..
Thank you for any suggestions.. I got all night and I am motivated. Thank you.
