The gas side will work fine without the oil side connected. Disconnect oil line at pump, cover nipple with rubber boot from dealer or discount auto parts, same boot used to plug vacumn lines. Locate wiring harness at pump, disconnect harness connector, cover harness with boot from dealer or tape. Disconnect 2 wires from engine that lead to remote oil tank, cover or tape the tan wire. 50-1 in fuel tank.
