Open Water
- Apr 28, 2025
- 34
2.6 oz of oil per gallon of gas. Peace of mind.If anybody has any doubt left as to why Premixing is the better way to go...
This might help: A lot of these VRO using engines blew up because people forgot to refill their oil oil tank, or the connections had an air hole sucking air instead of oil.
There are simply too many things that can go wrong.
The vacuum fuel pump has been around since the 1950s, is cheap , easily repaired or replaced and works good.
So "Keep It simple and mix your own".
