1988 Rogue 2420
sphelps
I’ll pass on the sanding . My arms are still sore from the WM ... I’ll just stop by every now and then at least till the beer is gone ..🙂
You sure have your hands full with all that gellcoat ..
Chris51280
Ensign
Well, I subscribed and will be following you. I looked for awhile to find you in the forums with no luck. I can't find owners groups. Maybe I'm not skilled enough to roam through iboats forum structure.:confused:
Sam,
I use Alexa to put beer on the purchasing list every day..... it would be a sin to run out...
any time you want to swing by, let me know
S
I simply watch the postings for the day - tab next to new topics just under the forum header
tpenfield
Checking in . . . looks like a lot of work with the gelcoat & color scheme, but the boat should be a real head-turner. :thumb:
Thanks Ted. Im trying to get the gel done ASAP so I can get back to re-assembly.
my gauges come in on the 23'rd
A bit of work on the boat this week. recovering from a nasty sinus infection that took me down for a week
have the hatch cover blasted and waiting for primer
picking up gauges today from VeeThree factory
started by adding the glow-in-dark paint to the dash. may need to us a UV diode to keep it going, however the stuff works ok.
Bit of update on the dash. Awaiting my switches to start wiring.
however the gauges are in.
a bit of trimming some fiberglass for the new layout will be required
installation of the gauges and comparison to old dash layout.
tpenfield
It is interesting that the rocker switches are facing upwards (if I am seeing it correctly). Is water penetration a concern, or are they IP68 ?
Chris51280
Ensign
Is it stainless 316? Looking nice. You live in saltwater areas, correct? I have a new one made as well but I only got my hands on 304. But I'm in freshwater only
carling switches are water proof (IP 67). IP68 is for submersion beyond 3 meters. worst case, I spend another $6 for the switch.
however sitting on top is fine for the application. the surface is sloped at 15 degrees
The original carling toggle switches worked for over 30 years until the plastic bodies started breaking where the halves are snapped together.
7 steps forward, 5 to the right, 8 steps backward, and 6 to the left........
sanding the cap gel to buff......sanded thru in a few spots....Ship Happens....
and since I am on antibiotics..... I cant drink.... Uggh.....
Bit of progress and setback. the turbo in the daily driver took a dump, so I spent some time yanking that. getting it rebuilt with a larger compressor wheel and updated bearings (multiple bearings vs a single 2-row)
