1988 Rogue 2420
mickyryan
man , i feel you on the dash thing, but end result looks fantastic! where did you pick up the roll of black and red, i only found smaller rolls , would love to find a 250- 500 ft roll of it !
so, awaiting an order of 14 ang 16 gauge Packard (Delphi) connectors.....
I got some other things done.
been putting off assembling the vent boxes. mainly because its time consuming.
so, without further ado, pulled out the tin-knocking tools, vice grips, rivet gun, etc
using .030 aluminum so it forms easy
still awaiting the order from Amazon that was supposed to be here today. extra LED lights for the bilge, and the hose clamps for the remainder of the fuel plumbing.
mickyryan
looks real nice man! i need to adress the vents on mine i worry mud daubers will make it a home without a fine mesh
gutter screens from Home Depot. stainless, and about $3 for a 36 x 6" screen.
also works as a hood scoop screen
you cant possibly make this stuff up....... how does something out for delivery have a "carrier delay"
Hose clamps and LED's finally showed up
on another note, my upholstery guy is MIA. he had a scheduled routine surgery 3 weeks ago...... and now I cant get in touch with him.
he has two of my arm rests, and was supposed to stitch together my side bolsters, then move on to the new seat covers.
!@#$!@#$ local guys wont touch the vinyl I have because "they didnt supply it"
Mother-in-law wont use her upholstery and quilting machine on vinyl because it cost more than a car.
Fudgieknuckles......
Spent some time working on the gunwale bolster panels
the front panels need to be redone to be symmetrical. I softened the curves and relaxed the angles.
I am also getting rid of fasteners and securing with X-mas tree fasteners or hidden T-nuts
next panel being made. original wood has decided to part. I also am changing the panel a bit and relaxing the trim
Making templates..... 1217191941a_resized.jpg1217191941a_resized.jpg and yes..... ran out of whiskey....
each panel is currently epoxy coated, then hosed down with appropriate color to help visualize. I have since DA'd the panels and will be wrapping the trim in 1/4" foam prior to stapling the black and red vinyl.
the original panel used stainless wood screws. the new panels use 10-32 T-nuts and I bondo'd over the end to smooth it out. since I am stepping up the workmanship a bit why not go all out.
tpenfield
Ted, will the pics above suffice? PM wouldn't allow me to add pics without the dang forum footer obscuring the send button.
Yes, those should suffice, along with templates. :thumb: Can you send the old vinyl skins as well as the templates?
